01 s40 turbo surging idle and p0236 code
Old Feb 9, 2019 | 03:15 PM
Puprilla's Avatar
Default 01 s40 turbo surging idle and p0236 code
Ok i bought a salvaged 2001 s40 1.9t so far since buying it "not running" ive replaced the battery, the starter, the tcv near the air box, the map on the intake manifold, maf sensor, rewired the coil pack harness changed some hoses, changed burnt fuses got the headlight low beam to work and trunk to open ive cleaned the pcv system and throttle body with all the right tools and cleaners and changed the neg battery wire is was funky.. My problem is i still have codes p0236 for map sensor boost map that ive changed and some generic p0700 for the trans. When in drive after the car is warm at a stop it will almost misfire it seems to bog down and drop idle and rpms really violently so i parked the car turned it on at home and revved the engine from in the bay using the throttle cable it seems to dip way to low on the rpms and almost dies. Idk what else to do my other car was a jap g35 so im new to these turbo volvos if anyone could help it would be massively appreciated ive been working this car from death for 6 weeks now and need to get the cel to go away so i can register it. Pic just cuz
Aviatortroy
Mar 24, 2023 07:19 AM
ChemDad
Apr 13, 2018 02:18 AM
AGSchear
Oct 19, 2012 08:26 PM
russ3161
Dec 17, 2008 07:33 PM
ariston
Jun 29, 2008 12:24 PM
