2000 S40 - Very Low, Erratic Idle; Stalling
Old Oct 18, 2012 | 08:29 PM
AGSchear's Avatar
Default 2000 S40 - Very Low, Erratic Idle; Stalling
My issues with my 2000 S40 continue. I'm not out of the woods just yet!
Last week I replaced the FPR and IAC valve after the car wouldn't start without a foot on the gas pedal. It starts just like new now and has even eliminated my issue of a 8 to 10 second crank time.
However, despite the fix, I immediately got a new CEL code and now, a week later, a very low, rough, jumpy idle tonight. The code I pulled is P0113 - OBD-II Trouble Code: P0113 Intake Air Temperature Circuit High Input. This code has been there for a week and was present even without the issue of my low idle and stalling.
Anyway, the idle sat at about 200-300 rpm when stopped tonight, both in park and at red lights. If left alone it would periodically move up, step by step, to about 700, and then back down again after coming to another stop. Stalled out in the lot of the supermarket when I was backing out of my spot.
I have been searching for about an hour and figured that tomorrow I'll clean the the throttle body and see if maybe it helps. I also found that the MAP sensor can cause similar issues. I'll try cleaning that as well.
Note: I mistook what I now believe is a temperature sensor on the intercooler last week for the MAP sensor, and thus went and cleaned it with MAP cleaning spray. I don't think this could cause my issue, but I'm mentioning it for completeness.
Anyone have any bright ideas? I checked all my hoses (or tried to) last week before buying new parts, and didn't notice anything. I can always look more.
Thanks in advance.
Old Oct 18, 2012 | 09:51 PM
migbro's Avatar
IAT sensor on top of the intercooler.
Old Oct 19, 2012 | 11:09 AM
AGSchear's Avatar
Cleaned the MAF sensor, MAP sensor, and TB this morning with the according sprays. No luck with the low erratic idle problem.
Migbro, thanks for the suggestion. That sensor looks like it might be the cause of my CEL and a mechanic told me it might be the cause of my idling problem, but the evidence online about symptoms of a IAT sensor and my common sense make me think otherwise...
Now to figure out what to do next...
Old Oct 19, 2012 | 03:30 PM
migbro's Avatar
Wut? So you're saying the code and the mechanic are wrong. Because your common sense says so. Or do I misunderstand your point?
Old Oct 19, 2012 | 08:26 PM
AGSchear's Avatar
Well, the OBD website I linked to in the first post said there are no symptoms usually aside from a CEL.
A page on the ehow website here: Symptoms of a Bad IAT Sensor | eHow.com says nothing about a low rough idle.
My car has had a rough idle for about a year now and the CEL only came on last week. It's not something that started all of a sudden when the light came on. Plus, the light was on for a week before I started having trouble with the low idle. I drove over 200 miles. Wouldn't the symptoms show up sooner?
The mechanic didn't really hear the full extent of my issue, just that my idle was low. So maybe he could've given a false assessment over the phone. So yes, my common sense here is saying there's something else, like a possible vacuum leak, that has been developing over time without me seeing it.
vol740wa
Jun 19, 2014 12:18 PM
nybblesandbytes
Feb 16, 2012 09:58 AM
radio16
Feb 23, 2010 07:12 PM
elderzap
Nov 7, 2007 04:58 PM
SPJC
Nov 19, 2005 09:15 PM
