05 s40 cranks but no start
Hello I'm new to this forum and need some help my 05 s40 non turbo is in the body shop for a new door and all of a sudden wont start it will crank but no fire. I can smell fuel so pump must be working from other posts I suspect FPR but only see pics of 2001 or so is it the same on 05 and is there an "s" vac. line to pull to check for fuel?? any pics or part # a great help
Thank you: fuses all good I don't know if any codes stored? will the car display them or do I nee a reader? I can pull up codes on my Ram by cycling key The body shop ran the battery down trying to get it going so I need to get it back up. The battery only 14months old but my wife had to get a jump once before she got hit then no problems till now?
Well Hudini it was a fuse 10amp ECM under the hood I thought I pulled every one when it was in the body shop knowing there was nothing wrong with car when it went in so had to be simple fix!!! I had it towed to my shop charged battery to full--tested it put it back in no start then started pulling fuses again and found it. thank you for your help.
nightmarevolvo
Feb 4, 2023 06:20 PM
