08 S40 Trunk Latch
Old Nov 24, 2024 | 12:51 PM
carljk47's Avatar
Default 08 S40 Trunk Latch
I am getting a Trunk Open message on my dash even though the trunk is securely closed. it looks to me like the sensor for that is in the latch. there's 4 wires going into it.
Just wanted confirmation on that before I order a new latch. Wiring looks fine.
Old Nov 24, 2024 | 01:10 PM
AndyTSK2's Avatar
Hi, I've just bought an 07 S40 that came with the same recurring boot open message. Checking various forums suggested the most likely cause to be a broken wire inside the rubber loom cover between the lid and the car, which turned out to be exactly the fault on my car. There were 3 other wires with breaks in the insulation that I also reconnected and, because I had to cut the boot to see inside, I've bought a new loom to replace my taped up (working) version when the weather improves.
Cheers
Andy
Old Dec 2, 2024 | 08:46 AM
richardkonrad's Avatar
Yes a wire in the boot loom is quite a common problem , not just Volvo but many other cars , on the Volvo had to replace wires once in 19 years , in my Alfa 2 times in 8 years
RrCoX22
Sep 1, 2020 10:06 AM
Kathleen Kahl Stetson
Mar 20, 2019 09:21 PM
greg dake
Aug 19, 2011 08:18 PM
tasiasnow
Mar 9, 2011 04:24 PM
BlackDiamondBound
May 23, 2006 09:02 PM
