2006 V50 T5 AWD Oil Spraying From Oil Cap
Old Feb 2, 2015 | 08:47 PM
ThomasK's Avatar
Default 2006 V50 T5 AWD Oil Spraying From Oil Cap
So I replaced my PCV Breather / oil filter housing 18k miles ago. I don't know if its the cause but every time I open the hood there is oil on top of the cap and misting in the direction of the passenger. I let the car idle and tried to remove the cap while it as running. There was some pressure pushing up. I've already checked through the PCV brether lines and none are clogged. I've changed my oil every 3-4k miles so I find build up an unlikely suspect anyway.
Any ideas on the cause? I'm stumped
in the mean time the car runs fine i just wipe off the oil from the top every so often
Old Feb 3, 2015 | 04:58 AM
difflock54's Avatar
Have you checked the oil filler cap itself?
May need a new seal or even a complete cap replacement.
Old Feb 4, 2015 | 08:10 AM
ThomasK's Avatar
I ordered a new one a few days ago. Hopefully that's all it is. What concerned me was the presssure.
Old Feb 4, 2015 | 09:12 PM
ES6T's Avatar
That would concern me as well. There should not be pressure there.
Old Feb 6, 2015 | 10:50 AM
mf70's Avatar
Has this car had its PCV system overhauled as per the recall? Is the riser tube from the oil filter to the cyl. head corrugated or hose? Corrugated is brittle & bad.
The PCV recall replaced far more than just the hose; I believe there was a check valve IN the oil filter housing that was redesigned.
Old Feb 6, 2015 | 12:11 PM
ES6T's Avatar
The OP replaced the oil filter housing.
Old Feb 7, 2015 | 07:30 AM
ThomasK's Avatar
Yes, to answer the question. I replaced the whole oil filter housing and related hoses 18,000 miles ago. I had ordered the new housing from Ipd in 2013. I don't know what year the recall was?
sgould
Feb 11, 2014 07:53 PM
Sean Berger
Nov 27, 2012 07:26 PM
Qu33nofJuicy91
Apr 30, 2011 11:40 AM
andrei3333
Nov 14, 2010 11:23 AM
Capo Cam
Feb 21, 2008 08:20 PM
