2000 S40 brake issues; advice needed,please!
Old Mar 3, 2015 | 04:24 PM
FlaTider's Avatar
Default 2000 S40 brake issues; advice needed,please!
Hello, new to the forum, new to Volvo. Bought son an S40. Problem:
2000 Volvo S40
Son put all his weight on brake pedal to raise up off seat. Brake pedal began going almost to floor, difficult to stop car.Drove several days, then applied brakes and brake went all way to floor, had to use emergency brake.
Saw no leaks at master cylinder or on inside of wheels
Filled the empty reservoir, applied pressure to brake pedal several times. Reservoir almost emptied. Refilled reservoir. Put pressure on brakes, and discovered brake fluid pouring from BOTH front wheels.
Any help most greatfully appreciated.
Old Mar 3, 2015 | 04:36 PM
ES6T's Avatar
Gotta check to see where the leak is coming from. My guess would be the hoses. I've seen several burst.
Old Mar 3, 2015 | 05:36 PM
Hudini's Avatar
Both hoses have burst on my 2001, one at a time though.
Old Mar 3, 2015 | 05:49 PM
FlaTider's Avatar
Yes,I could see it being hoses or calipers, it's the fact that both sides a pouring at the same rate and same time that puzzles me.
Thanks for your input guys!
Old Mar 3, 2015 | 08:23 PM
difflock54's Avatar
My V40 failed a fitness inspection shortly after I first got her.
Turned out both of the front hoses had noticeable cracks near the end connections.
Often they have signs of bulging occurring where the inner tubing is failing.
Easy DIY job if you do your own maintenance and the hoses are not expensive parts.
Pay you to to check the rear ones at the same time but they normally last longer.
slsnumber1
Jun 2, 2012 08:02 AM
jbasilone
Apr 20, 2010 08:24 PM
cptn
Jan 18, 2010 02:46 PM
srhorn
Jun 18, 2008 07:42 AM
