2000 s40 keeps dying out
Old 08-31-2006 | 02:04 PM
vtech22's Avatar
Default 2000 s40 keeps dying out
when we start the car, it starts up at 1000 rpm and the car runs fine. but most of the time, and it starts at 500 rpm, when you try to push the gas it causes the car to die and it sounds like its like its starving for gas and it will just die. if i keep turning the car off and trying it again, after about 5 to 10 times it will work. but i need your help on what the problem is. thanks in advance.
Old 08-31-2006 | 08:51 PM
vtech22's Avatar
Default RE: 2000 s40 overheating, dies out
help me out please haha, im desperate.
Old 08-31-2006 | 09:09 PM
Check engine light on?
Does it really overheat or the Guage just says it is?
Old 09-01-2006 | 01:59 PM
vtech22's Avatar
ORIGINAL: tech
yeah the check engine light is on. sorry it doesnt overheat, that was my mistake, it just dies out all the time like i said in the first part.
Old 09-01-2006 | 09:03 PM
Get the codes pulled and Post them then we can help more from there.
Old 09-15-2006 | 12:00 AM
vtech22's Avatar
ORIGINAL: tech
sorry its not throwing any codes at all, please help me out i need to get this fixed.
Old 09-15-2006 | 08:33 PM
If the light is on when you drive then there should be codes.
It could me a ton of things.
But if you could get it to set codes that would really help.
Old 09-20-2006 | 02:35 AM
vtech22's Avatar
ORIGINAL: tech
yeah i know it could be a bunch of things but it doesnt throw any codes at all, the check engine light isnt on.
Old 09-20-2006 | 08:30 PM
Try unplugging the Mass Flow sensor and see if it starts and idles. (It will set codes for it).
Make sure you have fuel pressure.
Make sure you have no big Vaccum leaks.
Make sure you have good spark.
Old 10-01-2006 | 12:48 AM
vtech22's Avatar
ORIGINAL: tech
thanks im gonna try all of these things, i told my friend about it and he said it might be that the MAF sensor is clogged or something to that extent, do you think this could be possible?
Old 10-01-2006 | 09:49 PM
I wouldn't say clogged I would say maybe it is bad.
Old 10-18-2006 | 06:18 PM
vtech22's Avatar
ok guys i fiinally got the codes and i desperately need your help. here they are.
it shows 2 codes as stored and 2 as pending.
Stored:
P0341: Camshaft Position Sensor A Circuit Range/Performance (Bank 1 or single sensor)
P0335: Crankshaft Position Sensor A Circuit
Pending:
P0336: Crankshaft Position Sensor A Circuit Range/Performance
dont get why it shows one of them twice but i really need your help. what do these mean? thanks for your help.
Old 10-19-2006 | 09:53 PM
vtech22's Avatar
Default RE: 2000 s40 keeps dying out
bump someone please help me out
Old 10-21-2006 | 12:51 PM
The Cam sensor might be going bad.
Or has the timing belt been changed lately?
Old 11-18-2010 | 03:19 PM
gabegiovara's Avatar
Did you ever fix this problem? My Volvo is doing the same thing and is giving the same codes.
Daniel Sendelbach
01-11-2014 07:29 PM
ashleyk2011
06-16-2011 12:10 PM
bmlaporte
05-22-2011 05:34 PM
paulboddy
01-06-2009 11:56 AM
jon9851
11-21-2008 08:26 PM
Quick Reply: 2000 s40 keeps dying out
