2000 s40 rear alignment issues
Old Jul 19, 2013 | 02:24 PM
Bentboybbz's Avatar
Default 2000 s40 rear alignment issues
Hello all I have a 2000 s40 1.9 T engine code b4204T2 auto trans with 169 k on the ticker. Things I have already done(complements of the forum) coil packs x2-coil pack wiring x2-OE volvo spark plugs-spark plug wires-OE fuel pressure regulator-unstuck the shifter button--But now unfortunately my girlfriend hammered a curb and has knocked the driver rear alignment out of whack. I tried to have it aligned at Firestone but after ****** #1 2 3 and 4 could not get it aligned charged me for it anyway. Ok fine. But they really could not give me a reason why they could not except for "I can't get it to adjust I think it's stripped" They could not tell me what needs to be replaced or anything. I cannot seem to find any parts or info about this. I tried to upload some pics from IPhone but will not work. Any help is appreciated very much!!
Old Jul 19, 2013 | 04:48 PM
Hudini's Avatar
Is something bent? Surely the techs could see if a control arm was out of shape?
Old Jul 19, 2013 | 04:59 PM
Bentboybbz's Avatar
i would think right? they look ok to me. the tire is cupping badly also at low speeds it almost feels wobbly and makes alot of tire noise.wheel bearing is tight. also i am working on the pics now but the bolts ave what looks like offset circles on the bolt and a plate on the arm. looks like the adjustments and they said that they are stripped.cant find anywhere to buy them.thanks for response
Old Jul 19, 2013 | 06:35 PM
ES6T's Avatar
The bolts are stripped? Usually what happens is the ring the eccentric rides along snaps so then when you turn the bolt, it doesn't adjust anything. I've had to re-weld a few.
Old Jul 19, 2013 | 11:10 PM
Bentboybbz's Avatar
As soon as I read that I went outside with my flashlight jacked it up and it looks like its snapped in a ring around the bolt. Awesome. Can I just grab a few of those bolts from a junkyard and swap them out ?thanks much for the help
Old Jul 20, 2013 | 07:29 AM
ES6T's Avatar
The bolt isn't the problem. The eccentric portion of the bolt rides against that ring. When you turn the bolt and the eccentric moves, it changes the alignment angle. Because that ring snapped, turning the bolt does nothing for the angle. The ring needs to be moved back into place and welded.
Edit- I misread. The bolt is broken but the ring is in tact? Then yes, you can use junkyard ones but it would be worth buying them from the dealer as they are probably seized in the junkyard cars.
Old Jul 20, 2013 | 02:01 PM
Bentboybbz's Avatar
Talking
Awesome thank you very much I could not find any info on this and I didn't want to experiment on my own car as I still drive it. Ill get the new bolts and maybe the lower control arm bushing a couple end links for sway bar and new springs and then try to have it aligned again and let you know the results. Again I greatly appreciate the free info my friend.
Old Jul 20, 2013 | 03:19 PM
ES6T's Avatar
No problem, good luck
tr_car_nut
Jan 29, 2013 09:33 PM
CJ Sinc
Aug 2, 2011 02:15 PM
amx1800
May 14, 2010 08:25 PM
silly2bme
Apr 22, 2008 08:05 AM
Chkysbak
Oct 6, 2006 12:02 AM
