2000 s40 will not turn over when engine is warm.
Old Dec 22, 2013 | 08:23 PM
Stellar-warrior's Avatar
Default 2000 s40 will not turn over when engine is warm.
My 2000 s40 always starts right up no problems when the engine is cold, but if I drive it then leave for just a short while it won't even crank at all till the engine cools down a bit. I'll wait 10-20 minutes and it will start with ease. I know the battery and alternator are good, so I don't think it's a low voltage problem, And I replaced the fuel pressure regulator last winter. Seems to me like a sensor or computer issue, but I have no idea where to start, does anyone know what could be causing this? Any and all help is much appreciated.
Old Dec 23, 2013 | 01:25 AM
GlendaAlvarez's Avatar
i will too appreciate the help in this regard and hoping to meet soon being into the same trouble .. anyone ??
Tevida Side Effects
Old Dec 23, 2013 | 11:29 AM
Hudini's Avatar
Sounds like a bad starter. When it gets heat soaked it fails. Try making a temporary heat shield to see if anything changes. Maybe a small piece of aluminum over the starter to block some heat. Careful of touching the battery hot wire. That will cause a few sparks.
(Please do not buy a new starter on my guess)
Old Dec 23, 2013 | 05:56 PM
Thanks I will look into that, that could be it. From memory it seems the starter is shielded pretty well though, and it seems to crank smoothly when it does crank, not like any starter failure I've experienced before, although last year when I had a bad fuel pressure regulator the start had to crank for about 6 seconds before it would start, and I know that puts a lot of stress on it, so maybe indeed the starter is to blame. I will investigate later and post back. Thanks.
Old Jan 30, 2014 | 05:18 PM
The problem seems electrical, an it's not the starter motor for sure, that part works fine, could it be the starter solenoid? Or some kind of electronic breaker or something to do with the ignition switch possibly? Any and all help is much appriciated!
Old Jan 30, 2014 | 05:43 PM
You should check the starter and solenoid for power when you try to start it.
Old Jan 30, 2014 | 05:57 PM
Ok I'll do that, so I'm thinking here, if there is no power at the starter there is an issue with the connection to the battery, because I know my battery is good and strong, if there is power to the solenoid and it still won't start it is a bad solenoid but if there is no power to the solenoid when I try to start it, what would that mean?
Old Jan 30, 2014 | 06:06 PM
I would also clean the battery cables, wires and connectors real good.
Old Jan 30, 2014 | 11:48 PM
I know my battery cables are very clean and tight, but I will check the connections at the starter and maybe the main fuse is loose or something. I'll just do a thorough check of the power and ignition wiring.
Old Feb 2, 2014 | 09:11 AM
mickey1's Avatar
2000 s40 will not turn over when engine is warm. Ive had the battery checked, its good, Ive replaced the starter, so its good. When I turn the key to start, all dash lights come on, but the starter doesnt do squat. Could it be the ignition switch, or ignition immobilizer?
Old Feb 3, 2014 | 06:58 AM
Hudini's Avatar
Besides the ignition switch it could be the neutral safety switch on the trans. When it acts up try putting the car in neutral instead of park then try starting it.
Old Feb 10, 2014 | 07:01 PM
wilsonhepple's Avatar
Red face Help.!!
I have just registered here today, and I want to ask a question about my S40, but don't know how to start my own thread...(duh).
Can someone give me directions....
Thank you.
Old Feb 11, 2014 | 09:53 AM
Hudini's Avatar
Upper left side. Click on the rectangle box with black background and white letters saying New Thread.
Welcome to the Forum!
Squirt
Dec 29, 2020 02:53 PM
marciemiller413
Aug 6, 2012 09:33 AM
vonsean
Jun 27, 2012 10:28 AM
VoLvIzL
Aug 5, 2009 12:08 PM
phil22
Nov 16, 2004 12:14 AM
