2000 Volvo S40 - Instrument cluster
Old Jul 16, 2013 | 08:29 PM
jpjmustang's Avatar
Default 2000 Volvo S40 - Instrument cluster
Out of the blue the instrument cluster stopped working - all of it
no guages (no needles move) - no numbers displayed at bottom
Started checking fuses under the dash and under the hood
Any suggestions???
JPJMustang
Old Jul 19, 2013 | 08:29 AM
Hudini's Avatar
There are two electrical connectors on the back. Maybe one has come loose? The connectors are mounted on a slider. You line them up with the holes in the cluster and push the cluster until you hear them click into place. They could come loose over time.
Old Apr 15, 2014 | 12:05 PM
jpjmustang's Avatar
Question 2000 S40 Instument Cluster
Im back again - The last time around it ended up being the Electronic Control Module - (used / installed - $450).
This time a headlight went out - I pulled the battery to change - when I re-assembled - the cluster is out (this car is starting to kill me.....)
Now Im back again - cluster went out less than 2 years later.
Back to checking fuses - I see on eBay that if it ends up being the cluster - you can get it rebuilt for $150
Any other ideas before I run to the shop?????????????
Old Apr 15, 2014 | 07:23 PM
difflock54's Avatar
My guess would would be the ECM.
Try disconnecting the battery terminals again and join them together for say 15 minutes.
It resets the ECM assuming its not stuffed itself.
Reconnect battery and hopefully all okay????
Old Apr 24, 2014 | 05:35 PM
jpjmustang's Avatar
Default :-)
Thanks - Ill try it tonight
volvo5volvo
May 29, 2012 05:46 AM
laronsue2
Nov 30, 2010 10:55 AM
WezoWP
Feb 19, 2010 08:49 AM
thaje
Sep 3, 2008 10:32 AM
thaje
Aug 29, 2008 09:43 PM
