2001 Misfiring at higher rpms
Old Sep 24, 2006 | 03:07 PM
OHVolvo's Avatar
Default 2001 Misfiring at higher rpms
Need help. My 01 is misfiring at higher rpms. I had the codes pulled and they were misfire on cylinder 2 and catalytic converter. I replaced the the plugs this moring and still have the misfire. Any suggestions on what to try next? Coil wires?
Old Sep 25, 2006 | 08:56 PM
Default RE: 2001 Misfiring at higher rpms
Coils
Old Oct 1, 2006 | 06:48 AM
sandders08's Avatar
It is such an annoying situation where you experience what seems to be like a bad plugs wire or valve. The mechanic suggested that the valves be removed as well as replace inlet valves. He recommended removing the exhaust valves and to clean stems of carbon. Valve steam seals were also replaced.
Capthook
Sep 3, 2013 08:47 AM
omniahobo
May 8, 2010 12:24 AM
gendy
Jul 17, 2006 02:22 PM
s40volvoH
Mar 18, 2005 06:43 PM
