2001 s40, No injector pulse
Old Jul 17, 2015 | 09:50 AM
Team423's Avatar
Default 2001 s40, No injector pulse
i have a 2001 s40, I swapped engine from a v40 same year, I have put in new crank sensor, map sensor, fuel regulator, fuel pump, reman injectors and iap. I have 52-60 psi at rail. Tested injector signal with a Noid light, have prime pulse, but no running pulse. Have inspected every fuse. Have avg 12.3v on both sides of all fuses. Change ecm relay, and checked all others. Engine runs great when primed with fuel. So spark is not an issue. There is no code appearing, scanned with Matco proscan.
Old Jun 15, 2022 | 08:43 AM
Damien Joseph's Avatar
Gave you got this solved? I have the same issue with my car.
Syndave
Apr 29, 2020 06:30 PM
940gnome
Nov 7, 2017 05:49 PM
Josephvelderrain
2001-2013 model year V70
Jul 7, 2015 05:11 PM
saabvolvotech
Jan 3, 2014 02:57 PM
jea
Sep 11, 2012 12:15 AM
