2001 S40 / Oil blowing out dipstick, should I purchase it? Any thoughts?
Old Feb 6, 2011 | 08:51 AM
golfcartguy's Avatar
Default 2001 S40 / Oil blowing out dipstick, should I purchase it? Any thoughts?
Hello all. New to this group. Wondering if anyone could help me to make a decision? Looked at this 2001 S40, with 1.9t today. Less than 85k miles on it. Automatic. Looked fine, ran fine. (Did have a misfire cyl 3 and 2 cel on, which I assumed to be a coilpack?) Anyway, took it out and it ran and shifted fine. Ran it about 8 miles up the road at normal highway speed. When I returned, I noticed an oil smell. Opened the hood to find oil under the hood, and over the coilpack cover, and rails. Figured it came from the dipstick. My question is, is this common? Would I be looking at a clogged pcv system, or something more major? I have read some threads that talked about new o rings, but thought I would go to those more experienced. Any ideas or thoughts? Anyone? The car is reasonably priced, and frankly I want it, however, dont (or cant) afford a engine rebuild at this time.
Thanks in advance.
Old Feb 11, 2011 | 04:54 PM
Counselor828's Avatar
Check the oil cap. If the o-ring is worn or not fitting right, oil could leak out from under the cap and spray on the top of the engine.
Old Feb 12, 2011 | 11:36 AM
ed7's Avatar
ed7
Your thoughts about the crankcase vent system is correct. At this age, the system is probably clogged and has never been serviced. O rings are aged and are also a common problem. Could be a good deal.
Ed
kent cousino
Aug 31, 2013 09:23 PM
kockyhardrockr
Jan 14, 2013 05:49 PM
MrJARichard
Jun 15, 2010 06:24 PM
Kenaisteve
May 15, 2010 11:01 AM
chriscurran
Sep 17, 2006 12:38 PM
