2002 S40 - Drivers side corner headlamp
Old Jan 7, 2011 | 09:09 PM
Chrisk1254's Avatar
Default 2002 S40 - Drivers side corner headlamp
I am trying to replace the corner headlamp on my '02 S40 and it seems there is no easy way to access the power adapter and and tabs to remove the old one. Does anyone know of an easy way to replace this? Seems like it would be a no brainer, then again I thought the same about the power antenna that I;ve had no luck with. Any help is appreciated! Thanks in advance.
Old Sep 24, 2011 | 11:14 AM
Ben_shafer's Avatar
Should be only 1 screw on the top of the headlamp that you have to loosen and then it should pull right out. Ill take a picture in a minute
Old Sep 24, 2011 | 11:31 AM
Ben_shafer's Avatar
here ya go. You literally only have to unscrew that top screw and then just pull it out. hah just noticed this post is uber old
Johnny Hamm
Feb 2, 2013 11:40 AM
electric blue
Jan 12, 2011 04:46 AM
ToledoVolvo01
Apr 30, 2010 09:34 PM
