2002 S40 will not idle
Old Nov 27, 2005 | 02:58 PM
OHVolvo's Avatar
Default 2002 S40 will not idle
Car starts but will not idle. Took to autozone and they say it might be MAP or MAF sensor? Any ideas? Will the MAP or MAF being bad cause the car not to idle? Could it be a clogged fuel filter/fuel pump issue?
Old Nov 27, 2005 | 08:10 PM
finchy's Avatar
Default RE: 2002 S40 will not idle
Hi OHVolvo,
The MAF sensor is usually situated near the air filter element and can easily be changed by yourself. Before you pay silly amount of money replacing it, just unclip the electrical connector and re-sit it back into position, be careful though not to damage any of the conponents. It might change something you never know!!??!! If a garage has said its the MAF sensor try swapping it with someone that has the same type (If that's an available option to you?) just to make sure. Unfortunately when these things are on the way out they tend to pack up completely a lot of complex things inside that you just can't repair (DIY). Always start with the cheapest option, by all means change the fuel filters etc. it certainly won't do it any harm.
Hope this helps, keep everyone informed of the situation.
Finchy
Old Nov 27, 2005 | 09:00 PM
A couple of things will cause that code besides the MAF and MAP sensor. Look really closely at the hoses from the engine to the intercooler and to the turbo.
Also there is a hose that goes from the engine in the front to the intercooler. If it breaks it will not allow it to idle and throw the code for the MAF.
Old Nov 29, 2005 | 02:46 PM
OHVolvo's Avatar
I checked all lines and no leaks. I took the car to another auto parts store and it had the following codes: Coolant temp sensor, cad converter sensor, and MAF sensor. Temporary fix: Adjusted throttle linkage so we can drive. Earliest Volvo can check out the car is next Friday.
Will update next Friday.
Joe
Old Nov 29, 2005 | 09:23 PM
I would start by replacing the coolant temp sensor.
Old Nov 30, 2005 | 12:42 AM
VolvoTechCMC's Avatar
I believe there is a software upgrade for the temp sensor. Trust me I kno, I just had to pay for one that was sent back by Volvo under warr. ...............Dumbass Service manager.............gggggggggrrrrrrrrr......
Old Nov 30, 2005 | 03:50 AM
OHVolvo's Avatar
How would I find out if there is a software upgrade? Is the upgrade free?
Thanks everyone for the suggestions.
Joe
Old Nov 30, 2005 | 11:19 PM
You will have to check with the Dealer. No its not free It is like an hour labor and $30.00 for the software.
nkinkade
Feb 28, 2014 08:49 PM
DavidAR
Oct 4, 2013 09:59 AM
Jhow1222
Oct 2, 2013 02:07 PM
siddiq
Jul 20, 2011 07:11 PM
2002s40
Sep 18, 2010 05:02 PM
