Central locking add-on
Old Nov 3, 2005 | 07:07 PM
johnmc's Avatar
Default Central locking add-on
Hello folks please be patient its my first post. I've recently bought an add-on remote central locking kit for my 1998 S40, as it only has key operated central locking. When I recieved the kit (from E-bay) the instructions dont offer much help. Can any one advise where the central locking "control unit " is in a S40?
Thanks
John
Old Nov 3, 2005 | 09:00 PM
Default RE: Central locking add-on
Im not really sure on the 98 S40 we didn't get them here in the U.S. till 2000.
If you lock or unlock the drivers door manually does all the other doors follow?
Old Nov 4, 2005 | 07:48 PM
johnmc's Avatar
Hello
yes the key when turned in the drivers door lock will lock/unlock all the doors. Is it possible to add on the remote kit to this system?
Thanks for your reply
John
Old Nov 4, 2005 | 09:41 PM
What I would do is add an After market keyless entry system.Install a lock actuator in the door to the door lock rod.This way the one motor will do all the work. That would be the easiest way to do it.
Old Nov 20, 2005 | 08:28 PM
Black Beauty T4's Avatar
The S40/V40 remote central locking system is linked in to Volvo's alarm system, so if your car doesn't already have this then I suspect you will need to buy & fit an entire central locking system from scratch, unless what you have bought from eBay contains the fobs, radio signal receiver, relay and a linked mechanism to open the driver's doorlock thus, as Tech has said, activating the other locks on the car using the existing key-operated system.
BB
Old Dec 1, 2005 | 07:01 PM
johnmc's Avatar
Thanks for your help guys, sounds a bit beyond me to be honest, so I might be selling a remote locking upgrade soon.
Cheers
John
guptash
Nov 19, 2011 04:17 PM
Mass850
Oct 21, 2005 09:48 PM
test225
Oct 16, 2005 12:53 AM
giddingsw
Aug 11, 2005 02:00 PM
guptash
Feb 1, 2005 12:32 AM
