2002 Volvo S40 air conditioning acting weird
Old Oct 5, 2010 | 01:16 PM
chaya14's Avatar
Default 2002 Volvo S40 air conditioning acting weird
Hey all...so i finally fixed the fuel pressure regulator so my car actually starts properly so now i am onto my next issue!
When i turn the ac on it blows cold...but its like it gets confused if i turn it to auto... it blows at 5 for 2 seconds then stops then starts then stops then starts slowly then high... its like its lost its mind!
If i turn it to level one, two or three... sometimes it works properly and sometimes it hardly blows, but on level 4 or 5 it works fine.
Any idea whats going on?
Old Oct 5, 2010 | 06:31 PM
bucs19901's Avatar
I got the same issue...
Old Oct 5, 2010 | 08:43 PM
Hudini's Avatar
Make sure the control **** is fully left into the Auto position. Put a little extra "umph" when you twist the ****. Don't over do it, just a tiny bit more to seat it fully.
I had mine for several years before I figured this out.
Old Oct 6, 2010 | 10:51 PM
AutoNaut's Avatar
Your fan control transistor may be going bad. I had a similar but not the exact symptoms with mine. This thread may help.
http://s40concepts.net/forum/index.p...fan#msg_116536
Stan
Old Oct 7, 2010 | 08:52 PM
Hudini's Avatar
Had that problem too AutoNaut That problem manifests as the fan will only work on high. The OP's problem is the fan goes on for a second or two, then off for a couple seconds, then back on, then back off, and on and on. I found it's just the control **** is not 100% all the way in the Auto position. JMHO.
roybis
Jul 22, 2020 07:47 PM
jstarman
Mar 22, 2012 06:58 AM
jihae84
May 1, 2010 10:21 PM
rperkins
Sep 5, 2008 09:31 PM
