2003 V40 Fuel Injection Pressure Regulator
Old Jul 6, 2014 | 02:09 PM
motorgnomes's Avatar
Default 2003 V40 Fuel Injection Pressure Regulator
My first question here. I have a 2003 V40. I had read that hard starts are mainly due to Fuel Pressure Regulators. I was getting ready to install the new regulator, and I found that mine is part of the fuel rail. I have done some searches, but I haven't any information on ones that are molded into the fuel rail. I am not sure what my next step should be.
Strange.
Old Jul 7, 2014 | 04:44 AM
Hudini's Avatar
Does yours have what appears to be a cotter pin holding the round part into the fuel rail? On my 2001, even though the FPR was held on with a single 10mm bolt, there was clearly an outer portion and an inner portion held in place by a cotter pin. That metal cylindrical object is the actual FPR as it holds the spring and diaphragm. Check out the IPD website for a picture: Volvo Fuel Pressure Regulator - S40 V40 113785 9404583
Old Jul 7, 2014 | 09:39 AM
Here is a picture. It does appear to have a cotter pin holding the FPR in.
Old Jul 7, 2014 | 01:31 PM
Livens's Avatar
Thats it. Just stick a flathead screw driver behind the pin and lever it out. The FPR will pull out from the bottom of the housing. I removed the rubber hose running along the bottom of your pic too for easier access. Be sure the release the fuel pressure before doing this.
Also, I had to lube the new FPR with a little vasoline on the upper o-ring before it would fit into the housing far enough for the pin to be put back into place.
Old Jul 7, 2014 | 06:29 PM
I want to thank both of you for the great information! I was able to change it out in about fifteen minutes.
MntnDewMan
Apr 3, 2024 04:05 PM
sincos
Jun 30, 2014 06:20 PM
slsnumber1
Mar 15, 2011 02:55 PM
floydy
May 30, 2006 11:00 PM
edahlgren
Oct 7, 2005 09:53 PM
