2005 S40 Heater Core replacement
Old Jul 9, 2014 | 08:13 AM
sweedzel's Avatar
Cool 2005 S40 Heater Core replacement
I have a 2005 S40 that developed a wet carpet on the passenger side. I noticed that the coolant was low and after I pulled the carpet away from the floor, I noticed the sound proofing under the what I gather is the heater core was wet also. Does anyone have any experince in replacing this item. I found a used core on Ebay for 80 bucks but used.
Old Jul 9, 2014 | 01:04 PM
ES6T's Avatar
You sure it's coolant under the carpet and not water?
Old Jul 9, 2014 | 08:47 PM
Hudini's Avatar
Water, as opposed to coolant, being a sign of either the evaporator drain loose/clogged or the sunroof drain clogged.
Old Jul 9, 2014 | 08:55 PM
ES6T's Avatar
Yep. Both way more common. I've never done a P1 heater core and have seen dozens of clogged sunroof drains and multiple evaporator drains.
rvinson2
Aug 31, 2015 07:48 AM
dglee
Feb 11, 2015 06:26 AM
ycartf
May 6, 2013 11:19 AM
s40volvo
May 4, 2012 05:45 PM
azeezn
Dec 12, 2005 10:50 PM
