2004 S40
Old Mar 15, 2008 | 11:58 PM
MattS12290's Avatar
Default 2004 S40
I'm a newer volvo user, and have a question. Sometimes, when I go around sharp bend (not stop and turns) there is a whining noise. I don't know what it is am curious. I would guess something with the turbo??
Old Mar 16, 2008 | 09:32 AM
fourthsyde's Avatar
Default RE: 2004 S40
from experience, thats normally a sign of a wheel bearing. is it a high pitch, a hum, a squeel?
Old Mar 16, 2008 | 11:11 AM
MattS12290's Avatar
Kind of. I was looking around online at just general whining noises in cars, and I found something about power steering fluid. Could that be the problem?
Old Mar 16, 2008 | 12:03 PM
fourthsyde's Avatar
power steering will sound kind of like a higher pitch hum, that sounds like something is just holding it back from doing what it should... hope that explanation helps...
Old Mar 16, 2008 | 12:22 PM
MattS12290's Avatar
it makes the kind of creaking whine when i accelerate around a cirlce (if u understand). heres a basic diagram of what the situation is. i start from left side, and go right. (these circles are in a neighborhood and u have to keep right)
the green lines=acceleration
yellow=coasting
red=braking
red arrow=where whine/creaking noise is
Old Mar 16, 2008 | 01:27 PM
fourthsyde's Avatar
check the level of your power steering fluid, and the consistency, if you havent had it flushed yet... i would consider doing that
Old Mar 16, 2008 | 02:16 PM
MattS12290's Avatar
i actually just got back from buying new fluid. i checked it, and there was barely, if at all, any. i filled it up to the max line, and did a short test run around the block a few times. i tested when it would whine and it didnt. i will continue to monitor the level to see if theres a leak, but it looks like it should be fine. thanks a lot for your help
xcyx
Apr 11, 2018 08:47 PM
shelby187
Jan 8, 2012 03:59 AM
ninayaa@sayclub.com
Jun 16, 2010 01:35 AM
fritzlovesmary
Jan 1, 2008 11:17 PM
NIU2004
May 13, 2004 04:21 AM
