2005 2.4i spark plug help
Why are you pulling the head to change spark plugs?
Here's a write up w/pictures on changing plugs. It's for a turbo, but you it'll give you the general idea.
https://volvoforums.com/forum/volvo-...k-plugs-41321/
The plugs are under the coil packs under the plastic beauty cover. There are no gaskets involved in replacing the spark plugs that I know of. It's always recommended to use dielectric grease on the part of the coil pack that fits over the plug to keep it from sticking. Also use anti-seize compound on the spark plug threads to keep from galling the threads on the aluminum head.
Kim Gregory
02-20-2013 08:02 AM
futbolfan15
04-02-2010 09:56 PM
