2005 needs flywheel
Old Dec 30, 2019 | 01:36 PM
Elaine Williams Elko's Avatar
Default 2005 needs flywheel
I have a 2005 S40 that needs a flywheel. The car has 175,000 miles. Is this worth having done?
Old Dec 30, 2019 | 06:02 PM
Why does the car needs a flywheel - ie is the clutch slipping or you can see its missing a few teeth for the starter? Assuming you have a manual transmission, a used flywheel would set you back $100 (check car-part.com) and you'd want to replace the clutch as well. I'd expect that to run 1500 to 2000 for parts and labor. With an automatic, there's a whole lot less parts so the flywheel flex plates go for $50 but you'd still need 8-10 hours or shop time to drop the transmission so you'd still be in the $1000-1200 range. Your car's value really depends on condition and options. Assuming its not a turbo in good condition, the car's probably worth $2000. Turbos with a manual are worth a bit more... So by my math its probably worth doing if you expect to keep the car for a while. If you are looking to trade it in, you'll get more sympathy than cash at this point.
redline55
Jan 12, 2017 10:10 PM
Marwan Harb
Apr 18, 2013 06:50 AM
mcadrenaline
Feb 15, 2009 11:31 PM
SLVRS40T5
Mar 18, 2008 08:26 PM
crispinrr
Jan 4, 2007 03:26 PM
