2005 S40 Ipod Integration
Old Apr 9, 2011 | 06:03 PM
anfron913's Avatar
Default 2005 S40 Ipod Integration
Can anyone tell me the best/cheapest way to integrate an ipod with the 2005 s40. I see threads about fm modulation and gateway dension but they are from years ago. Is there anything now that is cheap and easy?
Old Apr 9, 2011 | 09:58 PM
AutoNaut's Avatar
The Gateway is the best solution if you have the Premium Sound. An FM transmitter is the cheapest solution. A modulator is middle of the road.
Old Apr 10, 2011 | 10:10 AM
anfron913's Avatar
Thank you very much. I do have Premium Sound but $500+ is a little pricy for me for the Dension Gateway. Will the FM Modulator even work? I called Best Buy and they said they could put a device in called the IS77 (Isimple) which is an FM modulator. When I researched this it said it cannot be done because my car as an amplified antenna. Does any of this sound legit?
If I hook up the IS77 (FM modulator) will it work or be fuzzy just like a transmittor?
Thanks for any help people. I am getting so frustrated with this. I just want to listen to music in peace without static!
Old Apr 10, 2011 | 10:43 PM
AutoNaut's Avatar
Others have added modulators to their 2004.5+ S40/V50. One tricky part is that the system does not have a standard antenna connector. However, it is the same as a 9V battery. You can get a 9V battery connector at Radio Shack.
I haven't heard a modulator but it should be better than the transmitter since you have direct RF signal.
Stan
Old Apr 10, 2011 | 10:48 PM
AutoNaut's Avatar
Just found this.
Swedespeed Forums - Looking for an iPod FM Transmitter? Look no further......
2007s40driver
Aug 25, 2008 09:41 AM
GChad03
Dec 26, 2007 04:08 PM
Irishfred
Feb 14, 2007 02:43 PM
muse654
Aug 22, 2006 05:28 PM
mphubbar
Aug 4, 2005 03:33 AM
