2005 Volvo s40 t5 HID LIGHT bulb failure !!!!
Old Mar 28, 2011 | 04:32 PM
bart4q's Avatar
Default 2005 Volvo s40 t5 HID LIGHT bulb failure !!!!
I have 2005 volvo s40 t5 want to install low beam HID 35W 6000K each time i try do this and trust me i bought already 3 different hid sets getting error bulb failure after 5-10min driving. It is any sensor has to be remove or any different headlights will fit s40. PLease HELP !!!!
Old Mar 29, 2011 | 12:06 PM
Mad Matt's Avatar
Did your car come with halogen lights originally?
Old Mar 29, 2011 | 04:56 PM
jmoney5611's Avatar
if its like the 2.4i, you can run your hids when you turn the light switch to its regular on position, if it is on the DRL option your hids will flicker out after a few mins or seconds depending on the year.
Old Mar 30, 2011 | 10:53 AM
bart4q's Avatar
Yes i have original halogen lights. i want to install low beams only .
Old Mar 30, 2011 | 10:55 AM
bart4q's Avatar
OK i will try this and see what happen and let u know- thx
Old Mar 30, 2011 | 04:27 PM
Mad Matt's Avatar
If you want HID's do it the right way and buy a kit to do the upgrade properly...
Sharphid.com
Old Mar 31, 2011 | 11:25 AM
bart4q's Avatar
Thank you very very much HID works !!!!
Old Apr 2, 2011 | 11:22 AM
mmnewcomb's Avatar
I had the same problem when I installed my kit. You need to buy an anti-flicker module. it goes between the HID wire and the Ballast. Solves the problem instantly no matter what position your light switch is in. I got mine from a company on Amazon but you can probably find them on any site that sells HID kits. You just gotta make sure you get the right one. The company sent me a set for a BMW and it didn't work at all. They had to resend me the correct set.
Old Apr 3, 2011 | 11:32 AM
bart4q's Avatar
ok thank you my HID works but have problems because flicks all the time.
Old Apr 3, 2011 | 12:17 PM
mmnewcomb's Avatar
Yeah when I installed my kit it worked most of the time but if you pull up behind a car you can see that the beam is flickering the entire time and like everyone else said it will eventually go out. the code cancelers are the way to go
Old Apr 3, 2011 | 12:46 PM
bart4q's Avatar
Can you tell me which company is good to get anti-flicker?
Old Apr 4, 2011 | 05:34 AM
mmnewcomb's Avatar
http://www.hidnation.com/cancellers.html
davej
Apr 22, 2011 08:47 AM
2005s60
Jan 19, 2011 01:50 PM
dads 740 turbo
Oct 24, 2008 06:54 PM
ryandev
Sep 10, 2008 11:05 PM
llcoollam
Apr 24, 2006 06:54 PM
