2006 S40 2.4i Coolant leak oilpan gasket
Old Jan 2, 2018 | 01:03 PM
ckeenan's Avatar
Default 2006 S40 2.4i Coolant leak oilpan gasket
Replaced my upper radiator hose which had a complete failure. However, I always like to double check the system when replacing a hose (something other than wear and tear usually is the culprit). Sure enough, I have a small leak coming out of the valve cover gasket on firewall side. The time it took me to find the leak, not sure if replacing the gasket is a job to tackle in my garage. Any pointers on replacing the gasket and other issue which would cause it to fail would be great. I pulled the codes an thermostat is fine, but the vacuum pump blew fuse 33. Replaced the fuse and doesn't seem to run when placing key in the ignition.
Ejevans34
Jan 5, 2014 08:54 PM
MikeySq
Apr 23, 2011 06:48 PM
cg23cpo
Sep 20, 2010 02:13 AM
topherwv
Dec 17, 2009 10:35 PM
bullit850T
Jan 29, 2006 01:14 PM
