2006 S40 Slapping Noise After Head Rebuild
Hello, I just recently took on the challenge of doing a head job on my 2006 volvo s40.
Everything went smoothly, I took the head to the shop to get pressured checked and rebuilt. I bought new head bolts and torqued them down to sequence, they all grabbed. I torqued everything down to spec and went smoothly.
I went to turn on and turned on first try no problem... Only thing is that it was making a loud slapping noise, sounds like it was a diesel engine. lol maybe an exhaust leak?
I left it on for about 15 mins, no change to noise, and no water in oil. I turned it off and turned back on, the noise is still there. left on for 45 mins still no water in oil or over heating issues.
there is no check engine light on and shows no pending codes, but does say "reduced engine performance" on dash and does have low idle.
I will attempt to upload a video.
Any help is much appreciated.
Any help is appreciated thanks!
any help is appreciated thanks!
Sure does sound like an exhaust leak.
The reduced engine performance on my 2005 was because the fuel pressure sensor had failed. The fuel pressure is controlled through voltage on the newer 2004.5 and up 2.4L and 2.5L engines. When the sensor fails the fuel pump doesn't produce the correct pressure under load and the result is the reduced performance message.
The nuts came off with the studs, I have a feeling I placed the gaskets incorrectly, I did have trouble holding them in place while install.
the gaskets did seem to go on both ways, so I went with my gut feeling and placed the rigid side towards the head. I have a feeling I placed them wrong is there anyway to remove the headers without removing the head?
