clicking noise
Old May 13, 2009 | 08:30 PM
Alex11's Avatar
Default clicking noise
my engiene is making a clicking noise, i suspect a valve not closing properly, though i checked the compression to see wich one it was it still read 150psi on the lowest, and the rest at 175psi, all of the spark plus have a normal color to them, is it still fine if i do to work with it tomorow? will it do any damage?
Old May 13, 2009 | 09:47 PM
Lifter might be bad.
Old May 14, 2009 | 07:56 AM
Psaboic's Avatar
Does the engine run smooth? Do you hear the noise only at idle or all through the RPM range?
Old May 14, 2009 | 11:23 PM
Alex11's Avatar
yes, it ran smoothly when it did the cliking noise. my better guess would be the lifters also, now ive taken the motor apart up to where i have taken the head of the engiene, there are two marks on one of the pistons caused by the two valves making contact, right now im too tierd to continue, ill take apart the valves tomorow morning, ill take the opprtunity to take off all the crease that built up over the years, maybe itll help the performance
Old May 16, 2009 | 09:35 PM
f8talh8red's Avatar
does it need oil?
Old May 17, 2009 | 06:56 PM
Alex11's Avatar
no it didnt, but the oil change was due, could that make the diffrence? by the way ive noticed that one of the pushers scratched the surface in wich it sits in, im sending the head to a specialist monday or tuesday, any idea what could if caused this?
Old May 17, 2009 | 07:11 PM
dan2286's Avatar
If the timing marks for the timing belt are off too much it can cause that. Was the timing belt done recently? Do you know when the tensioner was last replaced?
Old May 17, 2009 | 07:33 PM
Alex11's Avatar
i have no clue if the tensioner has ever been changed or not, ive bought the car used a few months ago, and if it would of been the timing wouldent it do that on every cynlinder?
Old May 19, 2009 | 08:59 AM
bestharry's Avatar
Sometimes its one cylinder that gets afffected first before it becomes apparent on the other ones. Was there any slack in the T-belt when you removed it?
nationm
Sep 11, 2006 09:02 PM
RedVolvo
Jul 28, 2006 10:42 PM
epcutter
Jul 25, 2006 05:23 PM
scartydog
Jun 23, 2006 05:25 PM
thejman
Jun 7, 2006 11:49 PM
