2007 S40 2.4 heavy vibration under acceleration
Old Jun 15, 2018 | 06:58 PM
JakeD's Avatar
Default 2007 S40 2.4 heavy vibration under acceleration
Hi I have a 2007 s40 2.4 and it has a bad shaking when accelerating (moderate to heavy acceleration) and for the life of me I can't figure out what it is.... I checked the engine mount on top on the passenger side as well as the CV shafts.... More advise would be awesome thanks a bunch....
Old Jun 16, 2018 | 06:09 AM
Hudini's Avatar
I would also check the bottom motor mount and aluminum bracket that connects it to the engine. When I bought my 2005 I found a crack in the bracket and the rubber in the mount was worn away.
Old Jun 22, 2018 | 07:34 AM
pierremcalpine's Avatar
I had a similar thing happening at 45mph and above. Turned out to the passenger side cv axle (the intermediate bearing). A replacement of the axle did the trick.
Old Dec 15, 2018 | 03:45 PM
Kurt Wickman's Avatar
Had the same symptom. I replaced both passenger and driver side cv's, no more shudder. I did both because I didn't think doing just one was very cost effective.
Old Dec 15, 2018 | 06:43 PM
habbyguy's Avatar
A worn lower control arm bushing might also cause a symptom like this.
Old Dec 21, 2018 | 12:46 PM
volvos80319's Avatar
Default Solved
It was the driver's side CV axil, the passenger side one had already been replaced and the mounts looked ok, the car feels like I am driving on glass, it is awesome thanks everyone!
crashin
Mar 28, 2022 03:05 PM
mortrubl
Jun 10, 2019 11:43 AM
speednut45
Oct 22, 2017 10:20 AM
Eric's S40
Apr 11, 2015 10:37 PM
jdjayakaran
Nov 18, 2010 04:08 PM
