s40 vibration
Old Oct 18, 2017 | 03:48 PM
speednut45's Avatar
Default s40 vibration
2001 s40 vibration on acceleration. I fix it by replacing the passenger side haft-shaft. grease leaking at wheel. I hope this helps others. At 20 mph and up whole car would shake bad on hard acceleration. Had all new tires. I got mine from Napa for under 100.00
Old Oct 19, 2017 | 07:16 PM
thanks for the share. did your axle make any noises/clicking etc prior ?
Old Oct 20, 2017 | 10:23 AM
technicalfoul's Avatar
We had to replace the passenger side axle on ours. Apparently the PO replaced it once, and there are some replacements in the field that are about a half inch short, and eventually slip out, leaving you stuck. That might be the source of your noise. Take a look at the axle where it goes into the motor and see if its all the way in.
TF
Old Oct 22, 2017 | 10:20 AM
speednut45's Avatar
Thumbs up s40 axle vibration
mt6127 there was no noise or clicking. thanks to all who reply to my thread. After reading all the threads, I went and replaced the RT. half shaft.
No more vib. on acceleration. the outer c/v boot was leaking grease>>>so I took a chance.
ocean238
Apr 17, 2008 06:20 PM
halo2maniak
Nov 20, 2007 11:01 AM
yuriy36
Oct 14, 2007 05:43 AM
ohskigod
Oct 23, 2006 11:15 PM
airapetov
Dec 20, 2005 12:23 AM
