2007 S40 2.4 won’t pass emissions- help
Old Mar 3, 2023 | 12:47 PM
  #21
Dancar's Avatar
Originally Posted by habbyguy
I always go up one menu level, and then back to readiness check on my own OBD reader, just to make sure that I'm not looking at "old data". I've never had an issue disconnecting the OBD reader without turning the engine off, though I guess I probably do it that way just because it would be the normal sequence (do whatever I'm doing with the OBD reader, shut the engine off and unplug and store the OBD reader).
so to be clear, while driving, you go up one menu and then back down? The reader updates the readiness while you drive correct? Just want to be sure I’ll be able to do this before I purchase it. You have been so kind and helpful. I really appreciate your assistance, thank you.
Old Mar 3, 2023 | 01:07 PM
  #22
habbyguy's Avatar
Yes, that process should provide you with updated readiness status.
Good luck with the test - hope it passes with flying colors (even it it's only black and white). ;-)
Old Oct 2, 2023 | 07:28 AM
  #23
Abbotn's Avatar
Was there any resolution to this?
I have a 2005 S40 that also is not passing emissions.
It's as if the computer is not remembering the data, all the monitors are always incomplete.
Does anyone know the module that stores the drive cycle data? Is it the CEM, the ECM or what?
Old Oct 2, 2023 | 12:31 PM
  #24
habbyguy's Avatar
Just to make sure - you haven't just reset any codes, right? Doing so resets all the readiness indicators to "not ready". If they are persistently showing that they're all "not ready", I have to think something is seriously wrong. ;-)
JBxc60
Sep 2, 2021 01:37 PM
Dr_Shakalu
Jun 2, 2018 12:33 PM
latemeg
Aug 29, 2014 09:28 PM
SadVolvoOwner
Intake, Headers and Exhaust
Apr 23, 2014 10:07 AM
cpfergus
May 6, 2011 08:29 PM
