2007 S40 water leak
S60_dopegurl (04-16-2020)
Reconnecting tubes at base
I recently found two small ponds in the back floor areas. It turns out the sunroof drain became detached at the base in the left front corner of the dashboard. I plan to cut the tube and add an extension to make it just an inch or so longer so that it is long enough to be inserted into the attachment in the dashboard. The way it is now, the two tubes barely reach each other. The problem is I can't get my hand into the corner to push the tube into the receiving tube. I actually need two hands but it is so narrow. Any ideas? Thanks.
