2007 Volvo S40 engine can not start with coolant leaking from engine
Old Aug 4, 2018 | 02:32 AM
stevewen's Avatar
Default 2007 Volvo S40 engine can not start with coolant leaking from engine
On the highway, there is white smoke from engine hood, stopped the car on the highway ramp and could not start the engine again, towed the car to my house and park on the drive way. I found it run out of coolant, I filled distilled water to trouble shooting and figured out the upper radiator hose was broken, replace upper radiator hose and refilled the distilled water, and I found the upper radiator hose is good but the leaking is from engine, I doubt it is the head gasket issue and can not seal. it maybe the high temperature damaged the engine parts after the coolant was leak out on highway, I don't know exact issue is, I was told it will cost at least 2k to fix the head gasket or 4-5k to replace the engine, the car has 95k miles.
Any suggestions.
Thanks,
Rick Buck
Apr 28, 2017 11:44 AM
mazurek7
Jun 15, 2012 02:30 AM
crzicrzi
Feb 29, 2012 10:41 AM
anna850
Sep 11, 2010 09:52 PM
