2008 Volvo S40 problem with start up?
(Disclaimer: I don't know much about cars or terminology so keep this in mind for your replies, thanks.)
This morning, I went to start it up and it wouldn't start up. On the dashboard it said, "Immobilizer try start again" and also flashed up with an anti-skid symbol of some type which it never has done before.
After 2-3 tries of not starting, I tried it again and it started up with no issue just like normal. I drove some place and turned it off and about 45 minutes later got back in the car and it started with no issues. The times it wouldn't start the only noise I heard was almost like a revving up of an engine. It wasn't like a clicking noise such as being a battery problem. And when it started with no issues, there was nothing abnormal noticed with sounds, etc. Just like normal.
Should I be concerned going forward? Thanks!
Did it sound like the starter spinning but not engaging the engine? That is usually a starter solenoid going bad. If it does it again you can get something to reach down and tap the starter to see if it suddenly catches and starts. (I'm just trying to imagine what would make the revving sound)
