2011 S40 PCV replaced; now throttle issue?
Old Dec 17, 2017 | 07:44 PM
Tcw126's Avatar
Default 2011 S40 PCV replaced; now throttle issue?
I have a 2011 s40 t5 and a few days ago it started whistling. Did a google search and found that it's a common PCV diaphragm failure. It ran for a few days then the check engine light came in. Still ran but today I was able to replace the old box with a new Volvo brand pcv box; 2 hours later it was replaced.
Problem was immediately after installing when I went to test drive it, the dash said Power reduced (forget the exact phrase) I couldn't get past 2k rpm. Pulled it back home and scanned the codes.
Checked all connections, hoses, etc and couldn't find anything out of the ordinary. Install was easy.
Checked codes and had a P0128 and P0171. Any reason why The PCV being replaced would cause this?
Old Dec 19, 2017 | 03:25 PM
Hudini's Avatar
Did you forget the fuel pressure sensor connector? Or maybe a pinch a wiring harness?
Tcw126
Dec 17, 2017 07:19 PM
plumsmooth
Feb 15, 2015 01:10 PM
MattyXXL
Feb 4, 2011 01:33 PM
sameyeham
Feb 20, 2008 05:31 PM
