AC blower/Battery Probs
Old Aug 23, 2021 | 06:55 PM
BrianTX's Avatar
Default AC blower/Battery Probs
my ac was working just fine until I started having battery problems. I don't drive it much, but I start it up every so often to get the juices flowing. one day after having to boost the battery the ac just didn't work.
anybody know if there's a connection between the 2 issues?
Old Aug 24, 2021 | 01:47 PM
check fuses? its possible you popped a fuse when you did the jump. Did you measure voltage at the battery with the engine running to make sure the alternator is charging?
Old Aug 25, 2021 | 08:30 AM
richardkonrad's Avatar
Besides the fuses no once the car is running the AC should work , probably due to little use the seals hardened and leaked , take it to an AC chaps they should tell you what needs fixing for free , then you can decide if its worth fixing , well thats how it works here in RSA
ysteinbuch
Aug 30, 2015 11:56 AM
VOLVASTIC
Mar 5, 2012 11:02 AM
marko
Aug 2, 2011 10:55 AM
akmwilliams
Sep 15, 2009 10:07 PM
NoleWithAVolvo
May 15, 2007 06:25 PM
