AC hissing and "perculating" sounds! Help
Old May 11, 2010 | 06:01 PM
bocaboca's Avatar
Default AC hissing and "perculating" sounds! Help
2000 s40 with 42k miles. Bought used and had lots of work done since getting it. When the AC is running it sometimes makes a hissing and gurgling sound much like coffee percolating.
Sounds like pressure building up up up...then sisssssss it is released. I am assuming it is the AC.
Any advice or suggestions appreciated. Love Volvo but this s40 has been a work in progress.
thank,
Old May 12, 2010 | 05:01 PM
jonesy1710's Avatar
Default Re Hissing Sound
Be sure its coming from the AC but i had a problem with hissing noise and after ALOT of investigating its coming from wind whipping through the passenger side wing mirror...odd i know!!!
Im having problem with the variable timing valve making like a clucking noise from time to time....also finding a rattling/vibrating noise from the rear window (i think)
Any ideas please ?
Kind regards owner of a much loved Volvo S40
Old May 13, 2010 | 12:42 PM
bocaboca's Avatar
Thanks for reply. Mine is def from under the hood and it's when I activate the AC switch. It makes a sound like air being released from a pressure tank. Then some gurgling sounds and a repeat of the air escaping sounds. So no window leaks or leaves in the doors.
Had my VTiming value changed a while back. Lots of little issues that seem to be adding up in the $$$. But the car has under 45k miles so I guess it's worth investing the $ to keep it running.
Good luck.
Old May 14, 2010 | 09:03 AM
imhereftw's Avatar
could have air in the A.C. lines, fixing this would require a recharge by a professional
Ripkord
Dec 28, 2018 08:28 AM
Rawbertd
Dec 12, 2012 01:05 PM
tv23
Feb 24, 2011 08:23 AM
Platinum52
Apr 17, 2008 06:10 AM
