2002 S60 2.4T Help: "Cylinder 2 mis-fire detected" & "Turbo Overboost Condition".
Old Oct 16, 2011 | 10:37 AM
winebrat's Avatar
Default 2002 S60 2.4T Help: "Cylinder 2 mis-fire detected" & "Turbo Overboost Condition".
We have a 2002 Volvo S60t & yesterday the wife was traveling out of town and about 20 mins. from our house the 'check engine' light started flashing and the car was running REAL rough. I ran the codes on it & it had a P0302 & P0234. After some 'internet' searching, someone mentioned that it might be the plugs. I replaced all 5 plugs with the Volvo plugs from the dealership (the car has 99,000 miles on it) and the old plugs had some slight 'cone-ing' and the 2nd from the passenger side plug (Number 2?) was just slightly different than the others. I put everything back in reverse order and it still is running a little rough and it's still pulling the same codes.
I'm going to search for vacuum leaks today, any tips on that besides listening and trying to source them? Also, does the computer 'brain' need to be reset by unplugging the battery after a plug change?
Thanks in advance for your help.
Chris
Old Oct 16, 2011 | 10:49 AM
winebrat's Avatar
Oh yea, I'm getting ready to replace the air filter.
Old Oct 16, 2011 | 01:19 PM
winebrat's Avatar
I'm guessing it was the coil on top of the spark plug. I switched out coil #2 with coil #1 and it is showing a code P0301. I have a single coil on order from O'Reillys for $52.00 & I will get it installed on Monday. I will post back if that fixed it.
Chris
If anyone that reads this post knows of a place to order the headlight wiper blades and a new oil filler cap from a site, what place would you recommend?
autoking
Jul 28, 2012 09:39 PM
West
Jul 25, 2012 12:03 PM
rvinson2
May 26, 2009 07:09 PM
johnwilton
Mar 16, 2007 06:52 AM
azmark
Jul 21, 2005 11:39 PM
