after market stereo
Old 12-28-2004 | 04:54 PM
Cypress's Avatar
Default after market stereo
I put an after market stereo in my 2000 volvo s40 ive had it for a while and plays good, but I installed a subwoofer and amp connected every thing now the stereo wont even turn on? I checked the car fuse it was ok, check the fuse in back of radio its also ok, thought radio was burnt out or something so I tryed my friends stereo and his wont work either* I dont know what eles to do, if any one has any ideas or hints I would appreciate it alot thanks!
Old 12-29-2004 | 02:42 AM
Default RE: after market stereo
You need to test for power with a test light first.If you have power to the wires you are supposed to then check for ground.Make sure the power antenna/amp trigger wire is not grounded any where.
Old 12-29-2004 | 02:42 PM
Cypress's Avatar
I found out what the problem was the dome (inside car) lights wasn't working so I checked the fuse under the hood next to engine and it was burnt out so I replaced it with a new one and now the lights work and the radio* so if anyone has this same problem take these notes down radio dont workcheck the fuse i guess it iterferes with the radio some how* and thanks Tech I appreciate it
Old 12-29-2004 | 04:31 PM
No problem anytime.
nkhlystov
12-14-2010 01:30 AM
marc_baltique
05-31-2009 01:51 PM
mweiss31
05-29-2008 03:36 PM
Sabi
10-21-2007 11:38 PM
ko_kidd
07-10-2007 02:16 PM
Quick Reply: after market stereo
