annoying squeeking sound!!
Old May 19, 2005 | 12:22 PM
gibbo's Avatar
Default annoying squeeking sound!!
Hi
When drivin the car, every time you push the accelerator i hear a squeek from near the gearbox or underneath the car from somewhere. Its only when u press the accelerator its like a hinge needs oiling or something.
Any ideas at all??
And, the main feed to my cigarett lighter is dead? all the fuses are ok. ive connected it to another live to get it going but when i pushed the lighter in it blew the lights fuse, but when using a incar mobile charger it worls fine!
any help at all would be great thanks
Old May 19, 2005 | 01:11 PM
Default RE: annoying squeeking sound!!
The sound might be from a bad motor mount check your mounts.
The lighter elememt is probably bad if the lighter socket works with other things and blows with the lighter.
There is also fuses under the hood.Check them to for the lighter socket fuse.
Old May 22, 2005 | 04:31 PM
gibbo's Avatar
thanks tech
Just for clarification, motor mounts would be engine mounts? is that right? i can only spot 2 of them, can u pls let me know where the rest of them are, and will simply greasing them do>?
Tnaks
Old May 22, 2005 | 11:13 PM
Yes the motor mounts are engine mounts.
There is 2 mounts under the engine.
There is one on the right side of the car.I have seen the inner part of the mount come loose from the outer bracket before.
There is another one on the left side of the car that goes to the top of the transmission.
heyitsomid
Dec 12, 2009 08:49 AM
C70CoupeMaui
Nov 26, 2009 02:46 PM
Nick0887
Jan 6, 2009 07:32 AM
Volvo V70R
Jan 24, 2008 09:24 PM
cazman
Sep 13, 2005 09:27 PM
