audio speakers
Old May 11, 2008 | 08:46 AM
ianparsons's Avatar
Default audio speakers
Front dash board speake, driver side, low volume only. Front door speaker, driver side, no sound at all.
Is this a connection issue or faulty speakers. How can I check?
Old May 11, 2008 | 01:31 PM
billofdurham's Avatar
Default RE: audio speakers
Check that you haven't accidentally changed the balance.
If the balance is OK I would suspect a connection problem if the other speakers, back and front, are working OK. The front door speaker is connected piggy back to the dash speaker so I would start there.
Old May 11, 2008 | 01:58 PM
ianparsons's Avatar
Thanks Bill
So I should try and pop the dash speaker out and check the connections on that one first?
Is it wasy to remove?
IP
Old May 11, 2008 | 04:33 PM
The speaker grilles clip into place and can be prised out gently. Thatwill give you access to the top of the speaker but I think they are held in with rivets. To get to the wiring you need to remove the panel under the dash and work from there.
Old May 12, 2008 | 02:47 PM
djerikd's Avatar
ORIGINAL: billofdurham
Actually, the rivets hold the dash cover to the supporting structure. The speakers are just held in by a small spring clip. Very easy to pry up and pop the speaker out.
m1964
Aug 26, 2006 11:29 PM
pam@picton.net
Aug 4, 2005 01:46 PM
Volvo240T
Jun 16, 2005 02:32 PM
pilot
Jun 21, 2004 07:25 PM
yng740gledriver
Oct 17, 2003 05:10 AM
