Bad wheel plates
The back plates on my rear tires have become rusted and weak. I believe they need to be replaced.
1. What is the technical name for these plates, I think each tire has them?
2. Are they hard to replace? I mean do you have to remove the whole wheel to replace them?
I do not what to call these parts so I am not sure what to look for when I go to a Volvo parts website. I hope they are too much trouble to replace.
Any help appreciated.
Thanks in advance.
Respectfully,
Newport_j
I have a 2002 Volvo s40. It has a 1.9 liter turbo charged engine.
Thanks in advance.
Respectfully,
Newport_j
No I am sure it is not the rotors. That is the question that I asked the tow truck driver this morning and he clearly said it was not those.
You can see these plates when you look directly through the tire's inner wheel. They are visible through the holes in the wheel hub.
Respectfully,
Newport_j
Respectfully,
Newport_j
I think you mean the rear splash panels, also knows as disk guards or backing plates or dust shields (every place I see them online is calling them something different!). It is a thin metal plate right behind the rotors and they curve around the edge of the rotor a bit too. For the right side Volvo PN: 30814871
Link: SKANDIX Shop Volvo parts: Splash panel, Brake disc Rear axle right 30814871 (1027461)
A bit pricey for OEM's but that is all I can find online... I would check a junk yard if I were to need to replace them.
They're called brake backing plates. You have to disassemble the brake rotor, brake caliper and wheel hub to replace them.
Backing plate, left: 30814870
Backing plate, right: 30814871
Attachment 12154
Attachment 12154
I saw on the web these plates are being sold by Mitsubishi and they are about 2/3 the price of the 2002 Volvo s40 plates.
Is this legit?
The part numbers are:
MITSUBISHI MB928790
MITSUBISHI M814870
Any help appreciated. thanks in advance.
Respectfully,
Newport_j
Is this legit?
MITSUBISHI MB928790
MITSUBISHI M814870
Respectfully,
Newport_j
