Battery drain - not alternator - ideas?
Old Jun 18, 2010 | 03:58 PM
Amra's Avatar
Default Battery drain - not alternator - ideas?
2001 Volvo S40 1.9T/110,000mi
Car is a no-start (just like battery was dead). Everything working fine until yesterday - the problem started in mall parking lot. Jumped car - worked fine. If you let the car sit for a while, you need to re-jump it to start. However, if you wait only a few moments - it will start up normal.
Replaced battery in 07/2009. I went to Autozone for a diagnostic. Battery was 12.1 (needs charge) - with car running jumped to 13.9 (which should mean alternator charging). If the car is running and I disconnect battery - the car stalls (like an alternator issue).
Any ideas? Electric issue with battery drain? Or just that pesky alternator?
TIA!
-a
Old Jun 18, 2010 | 05:34 PM
SVTfocusO3's Avatar
Sounds like the alternator according to that last test, but do a parasitic draw test to see if anything is drawing amps.
mal81394
Jan 6, 2015 10:15 PM
jbarnes
Jun 12, 2013 11:46 AM
imaitland
Oct 9, 2012 11:54 PM
AnEskimo
May 8, 2010 09:49 AM
cmercon
Feb 2, 2009 02:15 AM
