Blowing fuse #32
Old May 14, 2024 | 09:26 AM
Elthomas's Avatar
Default Blowing fuse #33
2004 s40 2.4i fuse help, keeps blowing fuse 32 for injector. What could be the cause
Old May 14, 2024 | 11:55 AM
Could be wiring or a device that's shorted. google around for a wiring diagram to see what's on that fuse's circuit Not sure if your model has a fuel injector relay or not - if it does try pulling the relay when doing your probing You can also start by disconnecting the battery and then probe to see where you see low or no impedence. You may need to isolate stuff like unplugging the injectors etc.
Old May 14, 2024 | 12:02 PM
Elthomas's Avatar
Thanks hopefully I can get this resolved.
Old May 14, 2024 | 07:30 PM
Elthomas's Avatar
Default More info
From what I see that fuse goes to the fuel injectors because our cars do not have an iac, I keep getting a misfire on cylinder four so I’m thinking maybe a bad injector or bad connector
Old May 21, 2024 | 09:09 PM
Niklas11Braun's Avatar
Have you recently done any work on the car, like changing the injector or any related components? Sometimes if something isn't installed correctly or if there's a problem with the wiring, it can cause these issues.
Also, check the wiring harness around the injector. Over time, the insulation can wear down, leading to a short circuit.
If everything looks okay there, probably that the injector itself is faulty and drawing too much current, causing the fuse to blow. Use a multimeter to check the resistance across the injector terminals. If the reading is way too low or high, it's likely a faulty injector.
Old May 22, 2024 | 01:11 PM
Elthomas's Avatar
My mistake, I apologize, I looked at the wrong number on the Fuse, it is the F33 fuse under the hood that keeps blowing. And please correct me if I am wrong, but that fuse is for the front heated O2 sensor.
mainelyvolvo
Jul 19, 2025 04:58 AM
Juan Hernandez
Jan 15, 2018 04:16 AM
collslee
Mar 2, 2011 05:19 PM
brianb
Aug 22, 2010 09:33 AM
alan - flitwick
Apr 14, 2009 11:04 PM
