boost pipe
Old Oct 13, 2018 | 05:06 PM
David Mullaney's Avatar
Default boost pipe
hi just wondering if anyone could help i have a split in my boost pipe its causing black smoke on acceleration well im 99% sure its that im just wondering could i damage anything by running it untill i get chance to replace it and is it easy to replace.
Old Oct 14, 2018 | 09:58 AM
What is likely happening is the engine is measuring the amount of air the engine is sucking in through the MAF sensor and injecting that amount of fuel but due to the split in the pipe you aren't shoving that amount of air in as some is leaking out and so it's running rich. Richer when accelerating as the air would be under more pressure and more air would be leaking out than when just driving at a steady pace down the road.
Best to replace it as soon as possible any you might need to change the plugs too as they are likely getting a build up of soot. At least pull and inspect a couple once you get a new tube to gauge their condition.
Old Oct 14, 2018 | 12:17 PM
cheers for the reply do you mean the injector plugs? ive just wrapped a exhaust bandage around it with plenty of ducktape im gonna ordwer the pipe tomorrow.
Old Oct 14, 2018 | 12:20 PM
Spark plugs. Try to accelerate as softly as possible. You want to stay away from boost as much as possible as that's what causes it to leak more and also the pressure might be able to overcome the duct tape and blow out.
Old Oct 17, 2018 | 07:12 AM
Hudini's Avatar
Is this a diesel engine?
Zakharov
Oct 31, 2014 11:41 AM
PatchyFog
Jan 4, 2011 03:20 AM
JTapper
Mar 9, 2009 04:14 AM
407flyer
Sep 28, 2008 11:04 AM
ROKCHEVS850T
Jan 12, 2008 08:41 PM
