Bulb Failure Relay
Old Sep 28, 2010 | 06:27 PM
rhuerta's Avatar
Default Bulb Failure Relay
Where is the bulb failure relay on a 2001 Volvo S40 turbo?
Old Oct 1, 2010 | 10:05 PM
Hudini's Avatar
Not sure yet. You having an issue?
Old Oct 2, 2010 | 07:58 AM
rhuerta's Avatar
Default Bulb failure relay
The bulb failure relay light turns on and off.
Does this light come on when a light bulb is out?
Thanks
Old Oct 5, 2010 | 09:32 PM
Hudini's Avatar
It's supposed to, yes. It can also come on with different wattage bulbs due to the difference in resistance. Does it come on when you do something like press the brake pedal? I would make sure each side of the car has the same wattage bulbs, i.e. both brake lights, both reverse lights, all running lights. You don't want a 25 watt bulb on one side and a 50 watt bulb on the other. It does not have to be the expensive dealer bulbs, just has to match.
davej
Apr 22, 2011 08:47 AM
2005s60
Jan 19, 2011 01:50 PM
Sofar.
Apr 13, 2009 02:25 AM
wyomingresident
Nov 16, 2008 09:52 PM
dads 740 turbo
Oct 24, 2008 06:54 PM
