Cabin air filter
Search is a wonderful thing.
https://volvoforums.com/forum/showth...ighlight=cabin
The second to the last has the official instructions.
BTW, make sure you have some Bactine and Band-aids handy.
Stan
Stan
1) Open driver side door
2) Position yourself behind the wheel
3) Turn ignition key momentarily to start position
4) Let key return to run position
5) Check that there is nothing behind your car
6) Place gear shifter in reverse
7) Back out of driveway
8) Place in drive
9) Proceed to your favorite car shop
10) Pull out wallet and pay the man
Seriously, isn't it odd to post this question in a thread about cabin air filters?
How many miles are on your 2008? If the shocks are bad then they are likely still under warranty unless you have exceeded the mileage. If not then star a new thread so that others can find it easily in the future and well explain how to change them.
8) Place in drive
8) Place in drive
I need to install new front control bushings on my S60R... You think these 10 easy to follow steps will help me too???
Hello everyone,
It is POSSIBLE to change it thanks to all your postings.
To make it even easier, use a RUBBER BAND to change the shape of the new filter. By placing the rubber band around the filter in the center area, you will change the dimensions of the filter and make it much easier getting in back into the slot.
Here's the scoop:
1- Put the rubber band around the filter and slide it towards the center of the filter so that it looks like an "hour glass."
2- Then partially slide the filter into its compartment, and once you get it lined up, cut the rubber band and pull it out.
3- Finish pushing the filter all the way in and screw the cover back in place.
BTW, I did remove and unplug the accelerator pedal to do all of this. It was quite easy.
Good luck!
-carlos.
2008 S40
Here's the scoop:
Good luck!
-carlos.
2008 S40
