camshaft install positions
Old Nov 1, 2022 | 04:13 PM
garnerdavid408's Avatar
Default camshaft install positions
had to take my camshafts out...and the careful markings i had on them rubbed off...now I have no clue how to lay these things in there...WE ALL KNOW ABOUT THE TOOL.....One way I put them in was looking at cyl 4 lobes on exhaust are pointing away...lobes on intake pointing towards you 180 deg. seperated....You can reverse this whole camshaft arrangement 180 deg so instead of cyl 4 now cyl 1 has the exhaust pointing away and intake towards you...so which is the starting position ??... there are absolutes...the slits on the bacj end are aligned with the tool...and the loebes are 180 deg apart...maybe ??? it occurs to me mahbe the loebes arent 180 deg pointing away from each other....actually I really havn't a clue doews anybody out there have an insight ??
Old Nov 1, 2022 | 07:06 PM
Sorry, Then use the tool or risk bending valves
Old Nov 3, 2022 | 03:20 PM
you missed the whole question...it was how to position... after the sprockets are off... the camshafts from scratch...the valve cover is off so given the slits on the back end are horizontal and secured with the tool....the question is what position the lobes are in.when you start....you can have the tool in there in two or more positions of the camshafts.....its where to start the camshafts......there is another ?? the lobes on the exhaust and intake cam are 180 degrees apart....like on cyl 4 the lobes on the exhaust are pointing away from you...the intake lobes are pointing towards you.....DO YOU GET IT ???
Old Nov 3, 2022 | 04:09 PM
the slits on the back end are horizontal and secured with the tool....the question is what position the lobes are in.when you start.....DO YOU GET IT ???
Certainly I get it - With the alignment tool I and my shop has used many times - the tool only fits one way. If you examine the slot on the end of the cam - it's not centered - it's slightly offset so that the tool will only bolt on one way.
I can't tell you what position the cam lobes are pointing - never looked.
Peace -
Sandy15
Feb 21, 2013 06:04 PM
LauraRis
Sep 21, 2012 03:35 PM
halve198
Dec 20, 2011 11:42 AM
lhoet
Aug 16, 2010 06:49 PM
JHudson
Jun 21, 2010 04:04 PM
