can you clean a vvt pulley
Old Sep 10, 2012 | 12:31 PM
donovan72's Avatar
Default can you clean a vvt pulley
Hi All (volvo s40 1.6 xs 2000 reg)
Is it possible to inspect /clean the vvt pulley without taking it off the engine? I have just changed the oil and it was really black & the oil filter looked like a burnt crisp? (previous owner had not changed oil for 30,000 miles)!!
I think the vvt pulley may be dirty but cant tell? I have cleaned the vvt solenoid and that works ok now but was really gunked up, thats why i think the pulley may be gunked up as well.
Many thanks
Old Sep 10, 2012 | 02:56 PM
Hudini's Avatar
Don't know about the UK but over here we use something like Seafoam to clean internal passages. You don't run it for long, like 500 miles then change the oil.
Also, an old school mechanics trick is to use a pint or so of ATF in the oil to thin it out and clean the built up crud. Basically change the oil but leave room to add a pint of ATF then top off with regular oil. Run it like that for 500 miles then change the oil and filter.
You do not want to remove the VVT gear. It isn't keyed or notched and can be installed completely out of synch unless you have the proper cam holder tool.
Old Sep 10, 2012 | 03:13 PM
donovan72's Avatar
Hi Hudini, thanks for your info. I have just checked on ebay uk and i can get a can of Seafoam. Do i just pour it into the engine where you put the oil?
Cheers
Donovan
Old Sep 11, 2012 | 12:43 AM
Hudini's Avatar
Yes. It thins the oil and cleans the gunk. It is a solvent. Follow the instructions on the can.
lkatze
Jul 31, 2023 12:07 PM
Hopper
1998-2000 model year V70
Sep 15, 2012 10:48 PM
russellsv40
Jun 2, 2011 12:02 PM
olddaddy
Jan 25, 2011 10:37 AM
mick1232
Jul 14, 2009 07:24 PM
