Cannot adjust the headlight level
Old Apr 1, 2008 | 10:44 PM
shadowlord's Avatar
Default Cannot adjust the headlight level
hi, i just purchased, an 05 S40 with ouut HID lights, and the car has hiot the deer before, it was fixed with a new light put in, but the problem is when i raise it all the way up with udjustment screw it will only light around 10ft in fron the car, drivers side is fine like it suppose to be. When i compare the haight of the beam on the garage door the passanger side is around 4inch lower than the (good) drivers side
does anyone know a way to fix this?like if an additional adjustment is possible?
thanks
Old Apr 2, 2008 | 12:47 AM
jonnyboyca's Avatar
Default RE: Cannot adjust the headlight level
can you take a picture of the headlight adjustment area? does it look like it was damaged because of the accident? stripped?
~jon
Old Apr 2, 2008 | 12:07 PM
shadowlord's Avatar
yea, i it appears there is no damage to sarrounding area, the headlight assembley has been replaced....
LionB
Dec 14, 2011 05:27 AM
Jimbo_Jones
Mar 29, 2009 07:12 PM
MIK911
Mar 14, 2009 02:35 PM
LSE
Mar 5, 2006 10:51 PM
Colin Carter
Oct 3, 2005 10:09 PM
