Car Won't Start After Rebuild
Old Nov 12, 2018 | 08:33 PM
Jesse Gray's Avatar
Default Car Won't Start After Rebuild
I have a 2005 S40 2.4i. Bought it broken down, worked with a mechanic to rebuild the motor. What caused it to break down was some sort of timing malfuction, causing the timing belt to slip and damage a couple of the valves. So we tore apart the engine, replaced the damaged valves, rebuilt the cylinder head, threw in new rod bearings and piston rings, resealed the oil pan and pump, replaced the timing components INCLUDING the VVT Cam gear (which is what we believe may have failed in the first place). After putting it all back together, the engine will turn over but won't start, due to no compression (we did a compression test and it read about 5-10 lbs of pressure). We know the timing is perfect, and it's not any sensors or fuses/relays, coils, anything like that. And yes, we've tried squirting oil in the cylinders as well. So we're at a loss about what could be keeping this thing from starting. Any suggestions would be more than appreciated.
Old Nov 12, 2018 | 08:55 PM
Hudini's Avatar
5-10 psi? Sounds like you still have timing issues is my first guess. And you could have bent the new valves (hope not but still). Did the engine bar over easily before you cranked it? Have you done a smoke test?
Old Nov 14, 2018 | 08:45 PM
timing could be off but I'd think you'd get something higher than 5-10 PSI. sounds like its time for an inspection cam or a leak down test.
Old Nov 15, 2018 | 12:13 PM
firebirdparts's Avatar
I'm surprised it's not zero, myself. You're close on timing. To get 10 psig you'd have to be pretty close.
Old Mar 13, 2019 | 02:08 PM
usmarine0905's Avatar
Hash has an answer of find been stated. My S40 is the same way
vcolper
Jan 23, 2016 07:47 AM
Dragonhawk
Feb 25, 2015 11:34 PM
Cannon3231
Engine & Internal
Nov 2, 2013 12:18 AM
raphster
Apr 19, 2010 09:41 PM
dalborn
Jul 21, 2005 09:52 PM
